Teresa Waderker
#1 Posted : Thursday, September 25, 2008 2:04:19 PM(UTC)
Teresa Waderker
The bake element on the stove stopped working. I pulled the panel off of the back of the oven and saw a burned wire at the bottom where the wire meets the pole of the heating element. Can I just replace the bake element or should I not bother and just get another stove?
libertyappl
#2 Posted : Thursday, September 25, 2008 2:42:29 PM(UTC)
libertyappl
You can replace the element (part # 316075103) just make sure the wire has a good connector to the prong on the element.
Teresa Waderker
#3 Posted : Thursday, September 25, 2008 3:19:57 PM(UTC)
Teresa Waderker
The end of the wire is burned and the prong is also burned off where it originally connected. Does that mean I can't replace?
libertyappl
#4 Posted : Thursday, September 25, 2008 7:40:53 PM(UTC)
libertyappl
You can replace it, just put a new connector on the wire and make sure it's secure.
Nat
