2 Pages12>
spark3542
#1 Posted : Wednesday, September 24, 2008 3:51:18 AM(UTC)
spark3542
Dryer tumbles, but no heat. Igniter does not light, and no actuation perceptible in coils.
Igniter reads 63 ohms
Flame sensor reads 0-1 ohm.
Gas coils both read open.
I was about to order new coils, then upon further review on this forum, I read that the coils may still be good, even with no continuity reading.
My question. Is there another thermostat or device that I don't know about that would "trip out" the gas circuit? I don't see anything else on the exploded diagrams.
Mark in MA
SublimeMasterJW
#2 Posted : Wednesday, September 24, 2008 2:04:44 PM(UTC)
SublimeMasterJW
If this puppy:dryer coil kit.jpg has no continuity or is open then that glowbar will not come on.
SublimeMasterJW attached the following image(s):
SublimeMasterJW
#3 Posted : Wednesday, September 24, 2008 2:07:38 PM(UTC)
SublimeMasterJW
If the lint cause the fuse mounted on the blower housing to blow then the glow bar won't come on but the dryer will run! overload 1.jpg
SublimeMasterJW
#4 Posted : Wednesday, September 24, 2008 2:10:11 PM(UTC)
SublimeMasterJW
check it out:glowbar.jpg On this here particular dryer the fuse will stop power to the gas carrying device but the dryer will continue to run.:D
SublimeMasterJW
#5 Posted : Wednesday, September 24, 2008 2:12:29 PM(UTC)
SublimeMasterJW
The filter housing must be removed and washed out. The blower compartment will need to be vacuumed. The whole dryer will basically need to be cleaned and the vent pipe too. Or that fuse will continue to blow.
vondukeap
#6 Posted : Wednesday, September 24, 2008 5:41:37 PM(UTC)
vondukeap
My ignitor is itermittent. I opened dryer and found large compacted lint ball near blower fan. Cleaned out everything in front around blower but not vent in back. Still itermittent. Ignitor glows about every 3rd or 4th attempt. Checked all elec parts except thermal fuse and flame sensor. Looks like I would have to disconnect gas line and remove gas assembly to get to flame sensor. Any suggestions?
spark3542
#7 Posted : Wednesday, September 24, 2008 5:43:35 PM(UTC)
spark3542
Awesome.
I don't have access to the dryer again until tomorrow night, but I'll jumper the fuse out to confirm operation, then replace it.
I'll keep you updated.
Thanks for the help
SublimeMasterJW
#8 Posted : Thursday, September 25, 2008 8:55:39 AM(UTC)
SublimeMasterJW
The dryer needs to be completely cleaned out and the vent pipe too. You might as well take down the dryer and give it a good cleaning , then you can get to the flame sensor easier with the drum out of the dryer.
vondukeap
#9 Posted : Thursday, September 25, 2008 6:32:01 PM(UTC)
vondukeap
Did I imagine it? Upon further inspection, the ignitor comes on followed by gas and flame and alls good for the first few heat cycles. After that, ignitor glows but no gas. Don't hear the coils clicking anymore. If I stop and then restart dryer after a few minutes the same cycle repeats. Got new coils today, but same behavior.
I have not removed the drum, but I have now vacuumed out the blower area and inspected the vent pipe. All clear.
SublimeMasterJW
#10 Posted : Friday, September 26, 2008 5:16:21 AM(UTC)
SublimeMasterJW
Make sure your connections are all tight. Maybe you got a pair of dud solenoids. The dryer is supposed to cycle the gas on and off all during the cycle. Feel the solenoids when it quits and see if they are real hot to the touch. If so then they are probably bad.
2 Pages12>
