lichtfuss
#1 Posted : Wednesday, September 24, 2008 4:55:04 PM(UTC)
lichtfuss
Check lint light is on and thus won't start cycle. Took screen out and cover and cleaned thoroughly inside. Clean fan on front side of machine. Found tech sheet in back of control console and went through diagnostics but found zero errors. I even tried to disconnect moisture sensor but this did not help either.
I'm at a loss.
#2 Posted : Thursday, September 25, 2008 4:33:54 PM(UTC)
If you can post the tech sheets, it might help to provide more accurate advise.
