Sena
#1 Posted : Sunday, February 20, 2011 11:23:20 PM(UTC)
Sena
We had an electrical fire. The washer was on the same circuit. I went to do a load and...nothing. Checked voltage back to the inverter board. All good. The Red LED light on Inverter does not come on. There is discoloration around something that looks like a step-down tansformer and two small alluminum heat sinks. Board fried?
Any input at all would be much appreciated.
Sena
Jeff / APP Team
#2 Posted : Monday, February 21, 2011 5:48:44 AM(UTC)
Jeff / APP Team
If you have voltage coming to the board, but none coming out, then yes you have a bad board. Here is the part number. Part number: AP3204590
Sena
#3 Posted : Monday, February 21, 2011 11:25:18 AM(UTC)
Sena
Thanks for such a quick response. I did not check outgoing voltage at any of the pins. I wasn't sure what the values should be and which pin-set should be live when the washer isn't cycling.
Jeff / APP Team
#4 Posted : Monday, February 21, 2011 11:36:39 AM(UTC)
Jeff / APP Team
According to research, if the red led light is out on your board then it is bad, if you have voltage coming in. Hope this helps.:)
Sena
#5 Posted : Monday, February 21, 2011 11:38:49 AM(UTC)
Sena
Thanks Jeff.
