vrkruzer
#1 Posted : Monday, February 21, 2011 3:21:07 AM(UTC)
vrkruzer
The drying is always flashing and sometime during the cycle the delays lites come and and so willl the cancel drain lite. The unit seems to still run through its normal cycles.
Is there a rest function, is the always flashing drying lite trying an alarm to a bad heater?
Jeff / APP Team
#2 Posted : Monday, February 21, 2011 6:24:54 AM(UTC)
Jeff / APP Team
Sounds like you are getting moisture inside the panel causing your problem. With the power disconnected, try cleaning the ribbion cable and applying a thin coat of dielectric grease to the ribbon connectors. If that does not work, then you will need a new control panel. The part number along with the parts diagram link are below. Hope this helps.
Part number: AP3951373
vrkruzer
#3 Posted : Monday, February 21, 2011 7:07:35 AM(UTC)
vrkruzer
Thanks I think your right. I opened up the botttom and found the service literature and performed the test by taking the ribbon off and restarting the unit....the pump came on like it says and that test confirms that the panel is bad and not the controller. Also ran the service diagonstic cycle and it seems to be checking out....its was hard to tell beacuse it appears the wash light is out.....think thats the real issue.....
Jeff / APP Team
#4 Posted : Monday, February 21, 2011 7:12:33 AM(UTC)
Jeff / APP Team
I would try to clean it first, then if the same thing occurs , replace the panel.:)
