sergioge
#1 Posted : Sunday, February 20, 2011 5:27:51 PM(UTC)
sergioge
My GE dishwasher is not draining and it is not clogged, I have removed everything from the draining systme and hose. it seems to me that the pump is pot working, how can i make sure that is is the case and where can I buy the pump part number plaset 54070
#2 Posted : Monday, February 21, 2011 2:50:39 AM(UTC)
The model number you gave does not come up, please check it.
Model Number Locator
Note: If this is not a USA model then finding any info will be difficult.
sergioge
#3 Posted : Monday, February 21, 2011 10:45:22 AM(UTC)
sergioge
The model is PDW8280J10SS and I need to know how to make sure that the problem is the pump as it is not draining and it is not clogged, the pump number is plaset 54070
#4 Posted : Monday, February 21, 2011 1:38:26 PM(UTC)
Replacement parts for General Electric PDW8280J10SS Dishwasher | AppliancePartsPros.com
I am assuming this unit used to work OK for you and that nothing has been changed with the house plumbing.
You could try disconnecting the drain hose at the house plumbing and try draining it into a pail. This will eliminate a plumbing problem as a possible cause. Just be sure to hold the hose securely in the pail and put a towel over it so it does not splash all over.
Since you have checked the drain path and it is OK, I would measure the voltage at the drain pump when it should be draining. If you have 120 volts and it is not pumping then I would say that the pump is toast.
Also did you check the flapper valve (Item 328 in Section 5)
ncdave4life
#5 Posted : Saturday, August 9, 2014 6:21:14 PM(UTC)
ncdave4life
I repaired mine. Here's a picture:
http://www.burtonsys.com/GE_Profile_dishwasher/IMG_20140804_221817_75pct_annotated.jpg
I concluded that it was the thermal cutoff/protector, so I replaced the thermal protector with one I bought on a big online auction site (5 for $4.18, delivered, "5 pcs Motor thermal cutoff protector thermostat").
But I must have also inadvertently damaged one of the field winding connections, because it went "open" where it connects to the terminal. So I ended up having to reconnect it to its terminal with a short copper wire splice.
Photo of pump installed:
http://www.burtonsys.com/GE_Pro...4530_33pct_annotated.jpg
Pump removed:
http://www.burtonsys.com/GE_Pro...0140804_205056_33pct.jpg
Pump disassembled:
http://www.burtonsys.com/GE_Pro...5608_50pct_annotated.jpg
Discussion:
1. https://www.youtube.com/watch?v=...xtz404chvj4czatz35yauc0k
2. https://plus.google.com/...926990/posts/Pm22CgGqGeW
Siemens dishwasher pump keeps running (Dishwasher Repair)
by Fweigel 12/30/2023 4:35:28 AM(UTC)
Kitchenaid dishwasher pump? (Dishwasher Repair)
by Guest 6/11/2023 10:15:41 AM(UTC)
Mystery Ball Check Valve Shows Up In GE Dishwasher Pump (Dishwasher Repair)
by lokar 9/29/2021 8:04:19 AM(UTC)
Frigidaire Dishwasher Pump Wont Stop (Dishwasher Repair)
by badblue06 8/3/2014 6:54:58 AM(UTC)
Frigidaire dishwasher pumps water but doesn't wash (Dishwasher Repair)
by woodstock 3/19/2013 7:00:51 AM(UTC)
GE dishwasher pumps water out right away (Dishwasher Repair)
by redbeard 3/26/2012 8:23:13 AM(UTC)
Lubrication for KitchenAid Dishwasher Pumps and Seals (Dishwasher Repair)
by jsz 12/26/2011 4:36:43 PM(UTC)
Dishwasher pump not working (Dishwasher Repair)
by traain 12/20/2011 3:17:04 PM(UTC)
Dishwasher pumping out water during wash cycle (Dishwasher Repair)
by mcscott 7/2/2011 12:19:13 PM(UTC)
Dishwasher Pump seal replacement (Dishwasher Repair)
by mkapad 4/15/2011 7:20:50 AM(UTC)
Whirlpool dishwasher pump/motor (Dishwasher Repair)
by RandallRock 1/1/2011 11:19:56 AM(UTC)
kenmore ultrawash dishwasher pump filter (Dishwasher Repair)
by wheels16 12/22/2010 2:14:10 PM(UTC)
Admiral dishwasher pump assembly (Dishwasher Repair)
by OhYeahGreg 11/18/2010 1:22:50 PM(UTC)
ge undersink dishwasher pump/motor hookup (Dishwasher Repair)
by gwolever 11/13/2010 7:51:24 AM(UTC)
GE Dishwasher pump solenoid won't deactivate (Dishwasher Repair)
by mkthompson195 1/26/2010 2:00:18 PM(UTC)
