There are 4 Wash/Spin Speed settings on my top loading machine, but regardless of which setting I put it on it just runs at the Regular(Normal/fast) speed. The settings all worked up until now. Any ideas?
Your model has a 2 spped motor, most often one side burns out leaving only once speed running. The motor part number is AP3672573. It could possibly be the selector switch, which I would test first, part # AP3496312. Hope that helps you Nat
