drew11201
#1 Posted : Wednesday, September 24, 2008 5:03:46 PM(UTC)
drew11201
On our Amana Gas Range #ARGS7650 we tried the self-cleaning feature and now the oven door will not unlock.
Zanshin
#2 Posted : Wednesday, September 24, 2008 5:55:06 PM(UTC)
Zanshin
Most likely, the high temp from the clean cycle (over 900 degrees on some models) has deformed the small microswitch contacts on the door latch assembly so it doesnt know what position it is stuck in. You will need to get to the door latch catch or rod , release it and repair the fault. Most of the time you can access the latch assy from behind the grill or under the smooth top if this is one..
drew11201
#3 Posted : Thursday, September 25, 2008 5:33:16 AM(UTC)
drew11201
After checking out some other sites I found this suggestion that worked: turn the circuit breaker off for 5 minutes, turn it back on, start the self-clean cycle, then interrupt it. The oven door unlocked.
larrym1112
#4 Posted : Thursday, September 25, 2008 10:02:41 AM(UTC)
larrym1112
Glad you found the answer for your oven. I have the same problem and posted yesterday. No replies. Any other cites that might help me. Tappan oven more than 10 years old. Thanks. Larrym1112
crista67
#5 Posted : Friday, January 20, 2012 11:45:28 AM(UTC)
crista67
I have an older (2000 model - ARGS7650WW) Amana gas oven/range. The door latch got stuck between locked & unlocked when I tried to clean it and made an annoying beeping noise about every 30 seconds (until I hit cancel) and prevented us from using the unit. We shut off power to the stove for about 30 minutes (5 would probably work). When it came back on, the LOCK light was still on in the display, but I opened the door, pushed in the button to fool it into thinking the door was shut and the mechanical lock starting trying to move. I gently pushed it along into the unlocked position and it the light went off. I was able to successfully use the oven. Of course I'm not going to try using the self-clean cycle any time soon! Hope this helps someone else!
Rich510
#6 Posted : Thursday, March 8, 2012 1:41:43 PM(UTC)
Rich510
Door is locked and will not unlock
crista67
#7 Posted : Thursday, March 8, 2012 1:53:11 PM(UTC)
crista67
Rich - try unplugging oven for a while (see what worked for me, above). Does that work for your oven? Is it the same brand as mine?
Guest (5)
Maytag wall oven door won't unlock (Oven Repair (including Ranges and Cooktops))
by Guest 9/13/2022 10:44:59 AM(UTC)
Oven Door Won't Unlock after Self-Clean (Oven Repair (including Ranges and Cooktops))
by mmriowa 3/21/2012 10:45:47 AM(UTC)
GE Oven door won't unlock after self clean (Oven Repair (including Ranges and Cooktops))
by yeller123 1/6/2009 6:19:51 AM(UTC)
Oven door won't unlock (Oven Repair (including Ranges and Cooktops))
by jenga314 8/12/2008 2:12:03 PM(UTC)
Oven Door Won't Unlock (Oven Repair (including Ranges and Cooktops))
by BUDDY76 4/15/2008 4:17:53 AM(UTC)
