jackd3
#1 Posted : 18 years ago
jackd3
When my dryer starts up the heat comes on. After less than a minute the heat shuts off. I have checked all the venting, everything is clear. What could be causing the heat to shut off?
Pegi
#2 Posted : 18 years ago
Pegi
Does it relight every time after it shuts off? If so sounds like something is causing the burner to shut off on the hi-limit safety, see if the flame is lifting up tripping this safety thermostat...blocked air flow can cause this or a draft coming in from the dryer vent....can be other causes but check this first...
jackd3
#3 Posted : 18 years ago
jackd3
No it will not relight after it goes out. If I open the door, wait about a minute and restart, it will reignite and then shut off again.
No dryer heat (Dryer Repair)
by adamson 16 years ago
No Dryer Heat/No shut of in auto cycle (Dryer Repair)
by fred2117 16 years ago
No Dryer Heat (Dryer Repair)
by Warren 18 years ago
