fredf
#1 Posted : Wednesday, September 24, 2008 3:50:43 PM(UTC)
fredf
Hi
no water to icemaker. water dispenser is fine. Solenoids tested when i jump water dispenser plug to icemaker solenoid it pumps water. Red LED is flashing at on off switch wether flapper is opened or pushed closed. When i tested plugs for each solenoid voltage jumps to 110 for water valve plug no voltage at icemaker plug when arm for icemaker is pressed. Please help.
Advise if you receive this message:confused:
#2 Posted : Thursday, September 25, 2008 3:37:28 PM(UTC)
Originally Posted by: fredf Go to Quoted Post
...Red LED is flashing at on off switch wether flapper is opened or pushed closed...
The problem is a bad emitter and receiver boards. No doubt about it.
- The part number for the PC board kit is AP3137510
KitchenAid Superba icemaker no water (Refrigerator & Freezer Repair)
by SEATTLE PLUMBING QUEEN 10/8/2011 2:32:04 PM(UTC)
Frigidaire Icemaker no water to make ice (Refrigerator & Freezer Repair)
by mrtcontractor 1/13/2010 9:30:23 AM(UTC)
