Whirpool refrigerator intermittent not restart. once it is going everything going good. (making ice, both freezer and refri area are cold as normal). it ran for about a day and stop. sometime it can't start automatically. when it can not start the condensor fan is running but not the compressor nor the evaporator fan. I unplug for few minutes and plug in then it going again. What went wrong for the fridge? is the probem with run capacitor or restart relay -not enough power? what need to be fix and what would it cost to fix the problem. thanks in advance for your reply. already replace with new the defrost timer.
I would suggest the start device/overload & the capacitor maybe getting weak. Start device/Overload part # 8201799 Capacitor # 4387764. Nat
Thanks for quick reponse. do you have instruction or diagram for replacing these suggest components (relay, overload, capacitor). thx again.
These are pretty much just unplug the old and plug in the new and most of the time the start device/overload will come with the instructions sheet. nat
where is the capacitor mounted on this fridge? is this together with start device and overload. thx
it's next to the start device. Nat
The 8201799 comes with a very good manual in the box, It also comes with 2 overloads for different Models, Very easy to install and is most likely your problem!!! Good Luck!!!:)
Thanks for all your help.
