Katherine Schuler
#1 Posted : Tuesday, September 23, 2008 8:10:50 AM(UTC)
Katherine Schuler
according to my troubleshooting for my problem the possible cause is one of the 2 house fuses have blown. The solution shows replae fuse. Ok so what the heck is the house fuse and where do you go to replace this.. I've been told that it may be a thermal fuse, but according to the person I spoke to there is no thermal fuse..
libertyappl
#2 Posted : Tuesday, September 23, 2008 11:30:45 AM(UTC)
libertyappl
Turn your house breaker for the dryer, in your breaker box, off and then back on and see what it does.
Nat
Katherine Schuler
#3 Posted : Wednesday, September 24, 2008 5:36:23 AM(UTC)
Katherine Schuler
Yes I tryed that but still nothing. Whats next....
libertyappl
#4 Posted : Wednesday, September 24, 2008 7:13:10 AM(UTC)
libertyappl
Remove the rear panel and check the thermostats(remove one set at a time) with an ohm meter, for continuity. Also check the element the same way.
nat
SublimeMasterJW
#5 Posted : Wednesday, September 24, 2008 2:21:37 PM(UTC)
SublimeMasterJW
The fuse in this dryer will stop the motor from working. So if it still runs then you have a broken element:rear dryer bearing kit.jpg
SublimeMasterJW attached the following image(s):
SublimeMasterJW
#6 Posted : Wednesday, September 24, 2008 2:25:46 PM(UTC)
SublimeMasterJW
First remove the front panel: glowbar.jpg
