twojoints
#1 Posted : 14 years ago
twojoints
How do replace the oven hinge , the hinge is not in the door its on the
oven side thank you
abadfish66
#2 Posted : 14 years ago
abadfish66
you should see 2 screws where the hinges are attached to the oven frame. remove the lower drawer and oven door. remove the 2 scres that hold the hing to the frame and remove the hinge from underneath.
Caloric Oven hinge replacement (Oven Repair (including Ranges and Cooktops))
by firemante 16 years ago
