Hi, We just replaced the primary valve in our fridge, and turned the water on only to find out that there was a cracked hose leading into one of the ports on the secondary valve. The port has a small blue piece that holds it in place, and we tried to fix ourselves by cutting the hose past the crack and reinserting the blue circular "clamp" and the hose into the secondary valve. But we can't get a tight fit again. Can we just replace the "clamp"? And how do you get it back into the secondary valve with the hose for a tight fit? :confused:
Please help. Thanks!
