wapiwulo
#1 Posted : Friday, February 18, 2011 9:09:00 AM(UTC)
wapiwulo
washer used to fill then nothing no wash you could press cancel and it would drain, now front panel is stuck on "clean" tried unpluging no difference what if anything can I chek next?
Jeff / APP Team
#2 Posted : Friday, February 18, 2011 9:30:56 AM(UTC)
Jeff / APP Team
Is the clean light blinking or just stuck on? Did you check and see if the unit is in child lock program?
wapiwulo
#3 Posted : Friday, February 18, 2011 12:04:37 PM(UTC)
wapiwulo
light is blinking i actually counted 7 blinks then pauses and repeates,also cheked unit is not in child lock out mode, any sugestions ?
Jeff / APP Team
#4 Posted : Friday, February 18, 2011 12:22:45 PM(UTC)
Jeff / APP Team
That means the temperature sensor didn't see hot enough water. To fix this here is what you will need to do. Press Heated Dry, then Normal, then Heated Dry, then Normal back and forth within 5 seconds. This will put it into diagnostic cycle. Once it is finished you should be ok to use it. Try getting your water hot at the sink to prevent this from happening again. If you are getting the water hot at the sink, then you may have a heater problem. Hope this helps. Let us know what you find.
wapiwulo
#5 Posted : Wednesday, February 23, 2011 7:05:44 AM(UTC)
wapiwulo
Jeff I would like to thank you and APP the clean light stoped blinking and seems to be ok this weekend Il put it under counterfor the real testl but i'm pretty sure it's a done deal THANKS AND GOD BLESS
Jeff / APP Team
#6 Posted : Wednesday, February 23, 2011 7:21:10 AM(UTC)
Jeff / APP Team
Your welcome! Glad we could help!:) :)
cycle monitor stuck on clean.. (Dishwasher Repair)
by LATONYA007 10/18/2007 4:45:31 PM(UTC)
