Kenmore side by side, freezer seems ok but fridge has started freezing everything even on lowest setting, possible thermostat? Any help appreciated. Thanks Bruce
Originally Posted by: ApplianceJunk  Hi,
Yes, bad thermostat. Hello man thanks for the reply. well i vaccumed the unit out and recharged the fridge, used 5.25 oz. but now for some reason. the fan in the freezer is not running, but tested good, no power to the fan from the connector on back freezer wall. i need a service manual if anyone has one and or extra help llet us know thanks
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Originally Posted by: Bruce M  Kenmore side by side, freezer seems ok but fridge has started freezing everything even on lowest setting, possible thermostat? Any help appreciated. Thanks Bruce
