smccrainey
#1 Posted : Tuesday, September 23, 2008 6:55:57 AM(UTC)
smccrainey
The dryer is gas. It will turn on and spin however, it is not blowing hot heat. It it a thermastat? Or is there something that needs to light the pilot? Help!!!!!!!!! Single mother
libertyappl
#2 Posted : Tuesday, September 23, 2008 11:32:28 AM(UTC)
libertyappl
Rank:: Advanced Member
It could be a thermostat or possibly the ignitor.
Nat
smccrainey
#3 Posted : Wednesday, September 24, 2008 6:24:58 AM(UTC)
smccrainey
Nat,
Thanks for your response. I also reviewed the trouble shooting steps for this model dryer. It stated that sometimes the igniter will not work because of build up of dust. So I removed the back panel and vaccumed out all the dust around the igniter etc.. I turned the dryer on and it worked! It started blowing hot air. Thought this resolution may help someone who is having the same problem.;)
libertyappl
#4 Posted : Wednesday, September 24, 2008 7:11:51 AM(UTC)
libertyappl
Glad that worked, hopefully someone else can use that info!!
Nat
Dryer spins but there is no heat. (Dryer Repair)
by smccrainey 11/7/2008 6:56:15 AM(UTC)
