Oven is flashing F7 error and beeping 3 times and oven goes off. Of course, this is the only error # not listed in the manual. Can you please tell what's wrong and what I need to replace?
You either have a bad touch pad or control board. To test this you will need to turn off the unit, and gain access to the board. Unplug the ribbon cable for the touch pad. If the code comes back, then you have a bad board. If no code, then you have a bad touch pad. Here is the part numbers for both, and a link to the parts diagram. Hope this helps. Part number: AP2029572
Thank you very much! I will try what you said to do. You only gave me one part # and I think there are 2. Can you please send me the other one?
Your welcome. There should be two part numbers there. Look above each picture, you should see the numbers.
My bad. It's still early:) Thanks Jeff:)
Your welcome. Let us know how it turns out.
