dish washer is getting louder and louder during the wash cycle whirlpool gu1200xtlq2 how do i fix this will I have to remove the dishwasher to service it?
thanks
THIS FORUM IS DEAD!!!!!!! |
The chopper was broken blade of and jammed and round screen clogged I installed a new one but it is still loud not much difference
Is it filling OK?
If the pump's mechanical parts are OK then it could be that your pump motor bearings are on their last legs. |
filling fine
might just wait till it dies before buying the next one...
this was the problem with my kenmore/whirlpool washer. pulled the wash pump assembly and separated pump/motor from housing. the front motor bearing was shot. part of the brg housing of motor was eating away. it may have run awhile longer but replaced pump/motor (appliancepartspros) and were good for a few more years.
