sewcaps@aol.com
#1 Posted : Saturday, September 20, 2008 7:58:02 AM(UTC)
sewcaps@aol.com
The water dispenser stopped working about 3 days ago, yet the Ice maker and dispenser in the freezer door works just fine. I checked the micro switch at dispenser it was working. This is a Hotpoint the model number is the same as HSS25GFPEWW, HSS25GFPAWW, HSS25GFPDWW
libertyappl
#2 Posted : Saturday, September 20, 2008 10:15:59 AM(UTC)
libertyappl
If you model has a water filter check there first. Especially if you haven't change it in a while
Nat
sewcaps@aol.com
#3 Posted : Sunday, September 21, 2008 7:15:43 PM(UTC)
sewcaps@aol.com
I just changed the water filter. I am getting water to the conecter at the bottom of the door. I think it may have frozen from the bottom of the door up to the dispenser. I just don't know how to defrost it without emptying my freezer and turning it off.
#4 Posted : Monday, September 22, 2008 5:25:10 PM(UTC)
Check the freezer temperature. If it's bellow 0°F, adjust the freezer control for a higher temperature.
