washer is not spining its making ahumming sound when its suppose 2 b spining
Open the control panel and check the relay board (#17 on the diagram) for a burned spots and/or cold solder joints. - The relay board Part number: AP3097916
Originally Posted by: henrylunsford  washer is not spining its making ahumming sound when its suppose 2 b spining Henry, A couple of easy, mechanical checks you probably should make, before we go too far, Does the washer fill and wash and drain ? We can almost eliminate the lower components (motor, pump, and coupler) and concentrate on the control,or relay board first, if it does. Part number: 3407147R
