TnsBates
#1 Posted : Wednesday, February 16, 2011 5:33:11 AM(UTC)
TnsBates
I am having trouble removing the assembly that holds the agitator dogs on this model. It is about 7 inches down the center tube of the agitator and is securely fastened. It does not drop out when turned upside down. Will it screw off?
TnsBates
#2 Posted : Wednesday, February 16, 2011 10:21:01 AM(UTC)
TnsBates
Solved my own problem....the upper part of the agitator will separate from the bottom by force when pulled straight up--you will think you are breaking it--but once apart you can get access to replace the agitator dogs.
