ah right....wish it was that simple - both sides of the motor are single spades (flat metal)..the two and one things you see in the pic are just marks on the flat metal not pins. I need to somehow find out if the pink wire connects to N or L.
I can't see on the picture which is the N or L, but this looks like a used pump and as stated before the pink will go on the right & blue on the left.
yes it is the old damaged one that I took out. I just used it to take the photo. As you look at the photo photo N is left and L is right. So you are suggesting the Blue goes to N and Pink to L? If it is the wrong way will I damage the new pump/rest of dishwasher/or risk fire hazard?
Yes that would be correct hookup and it wouldn't hurt the pump if you accidentally hook it up wrong unless is 240V or something.....
Let us know if you need anythng else. Nat
