The washer has had no problems for about 7 years. Recently started going out of balance during the spin cycle. Any recommendations on how to proceed for adjustment....other than readjusting cloths over and over?
Thanks!!
Remove the front panel and check the suspension springs. Check all legs. Check if the washer is leveled properly. Here are the break down diagrams for the Admiral washer Model LNC6764A71Gene.
