abishek20
#1 Posted : Tuesday, February 15, 2011 12:57:15 PM(UTC)
abishek20
Hi, My microwave door handle has broken off. I have noticed similar complaints on this model from other people. However replacing the handle doesnt seem that straightforward. How do I get to the section where I screw down the handle? Which section should I open?
Appreciate any help I can get. Thanks.:)
Jeff / APP Team
#2 Posted : Wednesday, February 16, 2011 9:28:12 AM(UTC)
Jeff / APP Team
There should be an inner plastic panel seal. You will need to use a small screwdriver or butter knife to pry this off. Becareful and go slow not to break the tabs holding this in place. When removed you should see the screws for the handle. I'm attaching a parts diagram link, as well as the part number to help you with this repair.
Door controls grill and case replacement parts for General Electric JVM239WV01 Counter top microwave | AppliancePartsPros.com
Part number: AP2021140
abishek20
#3 Posted : Wednesday, February 16, 2011 12:09:37 PM(UTC)
abishek20
Thanks Jeff , will try out.
Jeff / APP Team
#4 Posted : Wednesday, February 16, 2011 12:25:30 PM(UTC)
Jeff / APP Team
Ok let us know how it turns out. Could help others in the future.
abishek20
#5 Posted : Sunday, February 20, 2011 11:23:35 PM(UTC)
abishek20
Hi Jeff,
It worked fine. However I did not have to use a butter knife to pry open the screen. The screw to the handle was exposed from inside. Perhaps my model is slightly different.
Thanks for your help.
Abishek.
Jeff / APP Team
#6 Posted : Monday, February 21, 2011 3:47:29 AM(UTC)
Jeff / APP Team
Your Welcome! Thank You.
