cpboudreaux
#1 Posted : Tuesday, February 15, 2011 8:59:37 AM(UTC)
cpboudreaux
When the dial is pressed to start the drying cycle, the display shows "Drying" but nothing happens. Also, I can hear an immediate click, which sounds like it is coming from a relay on the board "part # AP4045210.
I know this because I took the cover and board mount off and listened to it while I was pressing the dial to start the cycle.
Is it common for the board to go bad o this model, or could it be something else?
Jeff / APP Team
#2 Posted : Tuesday, February 15, 2011 11:06:31 AM(UTC)
Jeff / APP Team
Sounds like you might have a bad thermal fuse. Unplug the unit first. Then you will need to take the top panel off, then the front control panel. Then the front panel, all so you can get to the little 1" round thermostats under the drum. Check all the fuses for continuity. If one or more is open replace them. Be sure and check your vent if one of these are bad. Here are some part numbers.
Part number: AP4045367
cpboudreaux
#3 Posted : Wednesday, March 2, 2011 9:00:59 AM(UTC)
cpboudreaux
I ohmed all thermofuse's and were good. I did replace the thermister and still no go. Do you recommend I replace the board in question?
Jeff / APP Team
#4 Posted : Wednesday, March 2, 2011 9:08:25 AM(UTC)
Jeff / APP Team
Did you check the door switch?
electric dryer does not start (Microwave Repair)
by RayU 12/12/2013 7:03:52 PM(UTC)
Dryer does not start (Dryer Repair)
by Kalalau 9/20/2012 12:20:37 PM(UTC)
by hibidwns 6/25/2012 1:44:16 PM(UTC)
by Bharat 1/7/2012 4:02:37 PM(UTC)
Dryer does not start, can hear motor attempting to (Dryer Repair)
by bog 11/5/2011 9:52:03 AM(UTC)
by Raymond S 8/4/2011 8:35:52 AM(UTC)
Dryer does not start - Amana Gas (Dryer Repair)
by timjgtr 1/8/2011 10:10:33 AM(UTC)
Dryer does not start at all (Dryer Repair)
by timjgtr 12/26/2010 2:40:08 PM(UTC)
Gae Dryer Does Not Start (Dryer Repair)
by B Wall 9/10/2010 7:03:40 AM(UTC)
by D_Druz 3/1/2010 4:41:38 PM(UTC)
Dryer does not start, makes no sound (Dryer Repair)
by Pennell 11/12/2009 5:17:16 PM(UTC)
dryer does not start (Dryer Repair)
by petecardenas 10/19/2009 8:17:02 AM(UTC)
by petecardenas 10/19/2009 8:15:29 AM(UTC)
by bellaboo 10/1/2009 1:16:49 PM(UTC)
Amana dryer does not start (Dryer Repair)
by Barjensen 8/5/2009 4:21:07 PM(UTC)
