kingirp
#1 Posted : Tuesday, February 15, 2011 8:37:44 AM(UTC)
kingirp
Purchased in 2009. Received the board replacement that was part of a recall. However, now the machine will start in the middle of the night. It has a mind of its own once you choose a setting it will run through options by itself and change the run time and beeps while running. Ran diagnostic and it has a F70 stored in it but I am not sure if it is making that up:)
sidfink43
#2 Posted : Wednesday, February 16, 2011 5:53:02 AM(UTC)
sidfink43
Sounds very much like the board you now have is bad. Cannot find the F70 error code.
I would call Sears and see if they will send you a replacement board, particularly if the other replacement is less than one year old.
Good luck.
