My Whirlpool dishwasher door will not latch properly. It worked fine the day before. I checked the metal latch and the door and it just won't click. It doesn't appear to have anything in it's way. What else should I check to fix this problem?
Thank you!
There should be a spring in the latch. please locate your model number on the frame after you open the door you will see it. Nat
