jim45
#1 Posted : 17 years ago
jim45
I opened the frig to find that everything was warm and the freezer was not cold.
The power was ok the lights, water despenser, ice machine motor ran, but the compressor and condenser fan was not running. I checked the thermostat and it
read 0 on VOM .
The defroster relay goes on for about 3 seconds when I plug the frig in then goes off .
I checked the overload protector it was ok.
I put a meter to the fan and compressor and was not getting any power.
I put a wire direct to a outlet to the fan and compressor and they both ran. the coils in freezer were very cold . when I unplugged the cord from the outlet then plugged the frig cord in the relay for the defroster came on for a while and the defroster heater was warm, then shut off. but the compressor and fan does not run.
I am not getting any power to the fan and compressor . I have read that the compressor will not run if the defrost timer is on but this frig has the electronic defroster circuit.
libertyappl
#2 Posted : 17 years ago
libertyappl
It could be stuck on defrost.
nat
jim45
#3 Posted : 17 years ago
jim45
So even if this frig has a circuit board defroster and not the machanical type can it still get stuck in defrost mode. the defroster heater does not seem warm,
thanks Jim
libertyappl
#4 Posted : 17 years ago
libertyappl
The circuit board could have gotten hit with a surge and stuck yes, we have changed several of those boards out over the years.
Nat
aroxie
#5 Posted : 17 years ago
aroxie
Is there a diagram for Whilpool ref. model # ET8CHKXKQ0 0. The ref. is not cooling, fan is running, 3sec cycles. Ref. is 7 yrs. old. Need diagram for wireing and switches and relays. Where can I find this or where do I get a book from Whirlpool for this ref. Thanks. A Cooper
libertyappl
#6 Posted : 17 years ago
libertyappl
Here is the wiring diargram for your unit.
Nat
File Attachment(s):
ET8CHKXKQ00.pdf (323kb) downloaded 48 time(s).
