jkbrunda
#1 Posted : Sunday, September 21, 2008 10:03:37 AM(UTC)
jkbrunda
I baked in the oven two days ago. When the timer went off (I use the microwave timer) I noticed that the food was cooked, but the oven was off (no clock, no error codes, nothing.) I turned the 220 breaker off and back on. This brought everything back except the oven. So the stovetop and convection fan work fine but the oven will not heat. It does not display any error codes. After reading some posts on this forum, I decided to try the cleaning cycle and am waiting for that to finish, but the door still feels cold.
Any ideas?
Justin :confused:
fyxer
#2 Posted : Sunday, September 21, 2008 5:47:15 PM(UTC)
fyxer
bake element might be burnt out, sometimes this happen during a self cleaning session.
granville - FriendFeed
#3 Posted : Monday, September 22, 2008 2:34:05 PM(UTC)
If both Bake and Broil are not heating then, most likely, the problem is a bad control board (aka clock).
- The part number for the clock is AP3764682
