Hello,
The water of my washer Machine is not coming out during the spining process. The machine is taking water during the spining process. If I close the water supply, the water still coming in during the spining process.
Help me!!:confused: ,:( ,:)
Thanks,
Jvazquez
Not sure I understand exactly what you're saying. Your washer is not removing all the water during the spin cycle? And it's pumping more water in even after you turn off the water supplu? Nat
yes,
During the spining process the washer machine is not taking the water out, instead the water is coming in like when you start the washer process.. :confused:
Jvazquez.
Is this at the end of the cycle or just after the wash??
