when replacing tub seal and basket and brake assembly is the other seal that need replacing at this point
No, but it would be a good idea to replace the drive block since your going to the expense of replacing the basket & brake. nat
thanks for the help changed it all and it working at this time thanks Originally Posted by: libertyappl No, but it would be a good idea to replace the drive block since your going to the expense of replacing the basket & brake. nat
Glad you got it going!! Nat
