i was washing clothes yesterday dryed two loads and when I went to dry the third load...NOTHING! the dryer makes a humming sound when it is turned to an on position but when I push the start button nothing happens. I cannot afford to call someone out to look at it so any help would be greatly appreciated!!
Where does it sound like the hum is coming from? Most likely the thermal fuse blew or it partially tripped the breaker. Try to turn the breaker all the way off, wait a second then turn it back on. Test the dryer and let us know how it goes. nat
The humming sounds like it is coming from the control panel the knob that selects the cycle and drying time. I turned off the breaker and back on 3 times just incase it didn't work the first 2. I think you may be right on with the thermal fuse. Is this something you normally order online or can you get it at a local store.
Thanks for the answer!
You can get it either way part Number 3392519 or from here AP3132867 About $12 either way. Easy to replace. Nat
We fixxed it!
it was the thermal fuse and your right it was a breeze. Thanks
You're welcome and glad you got it going!! Nat
