2 Pages12>
nss
#1 Posted : Thursday, September 18, 2008 10:45:45 AM(UTC)
nss
This double oven was given to us. When I wired it up the pannel shows E1 and F2 errors. What do i do now? Would like to fix it myself. Thank you NSS.
libertyappl
#2 Posted : Thursday, September 18, 2008 1:17:38 PM(UTC)
libertyappl
The error code F2 E1 means the keypad is unplugged. If it has the trim pieces down the sides remove them and there should be a screw on either side of the control panel. cafefully remove that and check the connections. Post your results.
nat
nss
#3 Posted : Friday, September 19, 2008 5:10:47 AM(UTC)
nss
Thank you for the reply, i took out the control pannel and removed the band that connects the keypad to the board and then reinserted it. I still get the error. Is there another connection i am missing, do I need to clean the contact points and how if yes? NSS
libertyappl
#4 Posted : Friday, September 19, 2008 6:56:59 AM(UTC)
libertyappl
I would clean them. The easiest way is to use a pencil eraser on the male connectors, being carefull not to bend them.
Nat
nss
#5 Posted : Friday, September 19, 2008 9:28:26 AM(UTC)
nss
Nat, I cleaned the contacts with no change. Still shows e1 f2 and no response from the key pad at all. NSS.
libertyappl
#6 Posted : Friday, September 19, 2008 9:41:19 AM(UTC)
libertyappl
My guess would be the control board then isn't getting the signals from the keypad. Microcomputer part # 8302967 of AP3767567, depending on the color of the keypad as to which part number you may need. It may require both to get it fixed.
Sometimes hard to diagnose without being there.
Nat
alycat
#7 Posted : Tuesday, November 18, 2008 5:32:00 PM(UTC)
alycat
I am also getting this error message on my double oven. Funny thing is I had the repairman come put a new control board in today and now the keypad won't work. Originally he said the board was what needed to be replaced, but at least the oven was working! Now I got nothing!! The original problem was the upper oven kept heating to broil and not turning off,which is why we thought there was the problem with the control board. Could it be that the keypad was the thing that was wrong and not the board at all??? I'm going from this costing me just over 200 to repair to now the tune of 450 to repair both. Not sure what route to go now - try the keypad after the repair guy orders it???? Help!
libertyappl
#8 Posted : Tuesday, November 18, 2008 5:37:50 PM(UTC)
libertyappl
alycat,
I would call them back and tell them it's not working. It could be that one of connections isn't getting a good contact.
Nat
alycat
#9 Posted : Tuesday, November 18, 2008 5:44:15 PM(UTC)
alycat
Oh yeah - you are there! He came last week and from what I told him he said it must be the board. He saw that the keypad would not work when he installed the new one so I said why don't we try putting the old one back in so I will at least be able to use the lower oven without worrying about the upper one coming on and staying on. So he reinstalled the first board and that is when we discovered the error message coming up with the old board as well. I think hubby is now going to take a look at it tonight. I need the dumb thing, but how can it go from working like it was to not working at all. ARGH!!! The guy said that the keypad was probably wearing out anyway as well as the board. I'm not to confident with him right now. They are waiting on me giving them the word as to ordering the keypad.
libertyappl
#10 Posted : Wednesday, November 19, 2008 5:23:09 AM(UTC)
libertyappl
Well I think he should have check for an error code before installing the new board.
If you want to replace the keypad your self the part number is AP3131745 for the white one, on this site.
Keep us posted
Nat
Guest (11)
2 Pages12>
