billanddawn
#1 Posted : Wednesday, September 17, 2008 8:56:18 AM(UTC)
billanddawn
My Dryer Would Make A Little Noise When Started Only With Heavy Loads Like Jeans Noise Would Go Away After About One Minite But Now I Have No Heat, Drum Is Still Turning ,cold Air Is Blowing From The Vent, And The Timer Is ticking but not Working ,any Answers
libertyappl
#2 Posted : Wednesday, September 17, 2008 2:39:27 PM(UTC)
libertyappl
You probably have a blown thermostat or element. If you have an ohm meter your can check these pretty easily.
Nat
SublimeMasterJW
#3 Posted : Wednesday, September 17, 2008 6:20:21 PM(UTC)
SublimeMasterJW
The high limit is probably fried. Check it out: IMG_2010.jpg to the right of the pic is the heater element. At the top of the heat element chamber is the problem. That dang high limit is probably blown. The kit: IMG_2017.jpg Has both the high limit 250 degree limit (pictured on the right) and the higher limit 300 degree (pictured on the left,the smaller of the 2). The reason they give both limits is obviously the 250 degree limit did not work and the 300 degree limit got killed!. So both limits need to be replaced.:D
SublimeMasterJW attached the following image(s):
libertyappl
#4 Posted : Wednesday, September 17, 2008 6:38:42 PM(UTC)
libertyappl
These are cheaper than the element too, but I would test each part with an ohm meter to make sure before ordering parts. The above mentioned thermostats Whirlpool part number is 279816, element part number is 279838. (Almost funny when you know those parts off the top of your head)
Nat
Dryer has no heat. (Dryer Repair)
by Goatman48 2/12/2018 3:16:53 PM(UTC)
my roper dryer has no heat (Dryer Repair)
by vanj333 8/8/2012 3:11:18 PM(UTC)
Dryer has NO heat, but runs (Dryer Repair)
Belarus MCH_STL 7/12/2012 3:20:18 PM(UTC)
maytag dryer HAS NO HEAT! (Dryer Repair)
by gtopij 5/1/2012 2:13:30 PM(UTC)
Frigidaire Dryer Has No Heat (Dryer Repair)
by moody9207 4/22/2012 6:18:15 PM(UTC)
electric dryer has no heat (Dryer Repair)
by Anthony Cetani 1/22/2012 5:52:08 AM(UTC)
Dryer has no heat (Dryer Repair)
by marcustheman 10/17/2011 7:22:16 AM(UTC)
by Ken Louie 9/27/2011 3:50:23 PM(UTC)
Frigidare Dryer has no heat and timer does not work (Dryer Repair)
by qt3110 9/19/2011 9:05:10 PM(UTC)
by slowey 6/30/2011 11:47:52 AM(UTC)
dryer has no heat & wont run (Dryer Repair)
by K Graber 4/5/2011 10:34:19 AM(UTC)
by tbtpounce 3/24/2011 10:42:14 AM(UTC)
Gas Dryer has no heat (Dryer Repair)
by bmpaul 8/11/2010 2:48:42 PM(UTC)
by slim10 4/8/2010 8:10:12 AM(UTC)
HELP!!! Dryer has no heat (Dryer Repair)
by quinn9829 11/12/2009 6:44:51 AM(UTC)
