machine runs fine, drains and spins fine. all water is removed after the drain and spin. in the morning we find water in the drum, a nice puddle. so i said lemme look into this a little futher and found out the water is dripping from the inlet nozzle . can anyone tell me what causes the drip? is it the flow meter or the inlet valve? or something else. much thanks in advance for any help.............. jimmy
THIS FORUM IS DEAD!!!!!!! |
thank you much Denman. seems like its the cold water because i turned off the valve to the spiket and there was no water in the drum. thanks for your time and ur response ;)
JIMMBOD
