Need some help installing an igniter on my oven. Pictures would be a big help if anyone as them. Thanks
Do you have the part? If so post the number and I'll see if I can get you some detailed instructions. Nat
Part Number: AP205873 Manufacturer's Number: 12400035 (7432P076-60) made by MAYTAG
Hope this helps
Didn't find any preprinted instructions. I'll try to expain it, it's not a difficult job really. But it will be easier with two people. 1. pull the unit out & unplug 2 remove the rear panel & locate the wires to the ignitor 3 go to the front & remove the burner panel in the oven(at bottom) 4 look for the ignitor, unscrew the ignitor from the mount base 5 pull as much slack toward you as possible 6 clip the wires on the ignitor as close to the ignitor as possible 7 secure the wires from old ignitors to the wires of the new 8 pull the wires carefully to the rear of unit, do not lose these wires inside(this is where the other person comes in handy) 9 once wires are thru, hook them up and secure ignitor in place(making sure not to touch the ceramic part of the ignitor at any time) 10 plug unit back in and test, if working properly unplug and reassemble.
Note: Between steps 4 & 5, now would be a good time to inspect your burner for any damage, sometimes gas ovens will not light due to damage of the burner bar & not the ignitor.
Hope that helps
Thanks libertyappl, I will give this a go & let you know what happens.
Got around to installing my igniter & still the oven will not heat up? What would be my next step?
Check the oven sensor probe with your ohm meter make sure it's good. If not that part number is 04000051 Nat
