Freezer Part Of Refrig Stopped Freezing Food And Making Ice In Ice Trays
Pull the freezer back panel and check the frost pattern. If only partial frost, you have a sealed system problem for a pro. to look at. You might want to check in back of the fridg, to see if your compressor is running. If not running, post this info and we can help you with that.
