rick2336
#1 Posted : Monday, February 7, 2011 1:29:53 PM(UTC)
rick2336
I fixed the leak by replacing the tub seal and it seems to be running smooth through all cycles. Seems like it takes a while to spin down. What is normal? On a whirlpool direct drive the brake shoes stop it QUICK. This washer seems to take longer is this normal? Am I correct in that the brakes on this unit are not serviceable at all? Thanks!!
Rick
Joe / APP Team
#2 Posted : Tuesday, February 8, 2011 1:28:55 PM(UTC)
Joe / APP Team
Rick
Rick,
Yes you're correct,
The transmission and brake assembly is a single unit and not serviceable.
You'd have to tear down the machine, and replace the transmission.
Part number: AP2046402
As for the "ramd down" brake operation at the end of the spin cycle,
On average(most top load washers), it should only take a few seconds,or 2 to 4 revolutions of the tub before it stops(if it's working proper).
Is yours much more than that.
Is the tub still rotating when you open the lid completely ?
it should rotate1/2 to 1 more revolution, at that point.
:cool: :cool: :cool:
rick2336
#3 Posted : Tuesday, February 8, 2011 3:49:06 PM(UTC)
rick2336
Thanks! I am hoping to not have to replace the transmission. I did not try opening the lid to stop the spin. I was observing with the front cover off. Would that change how quickly it slows if the lid was not opened?
Joe / APP Team
#4 Posted : Wednesday, February 9, 2011 5:17:58 AM(UTC)
Joe / APP Team
Rick,
No, it should not make a difference in how the unit is stopped.
At the end of a cycle, raise the lid,any way you stop the tub from spinning, it should ramp down and stop in a few seconds.
I am not aware of anything to do except, replace the transmission assembly.
