My Maytag model # MAH5500BWW, serial # 98919282AV will not do anything and shows code "LO". What does this mean? Also doing the self test thing it showed a code of "ot" What does this mean? Thanks for your help in addvance.
The LO code is the door lock, either not actually locking or it's not telling the unit it's locked. the ot code I can't find anywhere. Nat
Thanks for the response. The "LO" door locked, does this mean door lock assembly is broken? I can hear the control board sending a plus every ten seconds. All so I bought the maytag used, can anyone tell me how old it is by the serial number?
It could be broken or not registering being locked. With the serial number I can tell you when is was made. Nat
How old is this machine? Is this machine worth putting a new control card in?
Your unit was made in November of 2002 Nat
I would, but I love my Neptune. Of course mine is a newer model, but when (not if) it breaks I will fix it! Because a new front load ins't cheap and I don't want a regular top load again. Nat
Thanks Nat I guess I will order a control card.:D
You're welcome hope that gets you going again!! Nat
