When I turn on the dishwasher the timer does not count down but he dishwasher seems to work and be "stuck" . Based on what I have read it seams to be the control module. I have taken it our already. Is there way to clear or erase the memory or does it need to be replaced if that is the problem
Hi GeorgeK Most likely the problem with your dishwasher is a bad control module. It is not repairable and has to be replaced. - The part number for the new control module AP2802870. Please, read the comments next to the picture. Good luck. Gene.
Originally Posted by: Gene  Hi GeorgeK Most likely the problem with your dishwasher is a bad control module. It is not repairable and has to be replaced. - The part number for the new control module AP2802870. Please, read the comments next to the picture. Good luck. Gene. Thanks I have ordered the part and sure it will solve my problem. Thanks for your help!
