gotoguy
#1 Posted : Tuesday, September 16, 2008 1:19:51 PM(UTC)
gotoguy
The quartz element no longer lights on the 5th and 6th settings of the switch- the ones used most often. Common?? Will a new switch fix or could it be the element?
#2 Posted : Tuesday, September 16, 2008 4:00:40 PM(UTC)
Most likely the problem is a bad switch but there is a small chance for the heating element too.
- The part number for the 10 step switch is AP2825518
Here are the break down diagrams for the Thermador stove Model CEH365VQW
