Alot of times on your dryer model, the idler pully wheel, sometimes drags, or even a roller begins to drag, and then it creates this tug and pull sort of effect. The motor turning full speed, and the rollers, or the idler pully wheel draging, and the next thing you know, rubber is flying. So, I imagine you got the parts real cheap on Amazon, so I recommend a drive system rebuild. As a tech, I tell my customers, that this is the best way to do it. That way, you don't have to keep calling me out to replace 1 roller, or 1 idler pully, then the belt. So, in the customers eyes, they are not able to do the repair, but you are. So, you save a ton of money, not calling me out, So, if you want to nip this in the bud, for the next 7 years, replace all rollers, the idler pully, and the belt. The parts, are not that expensive, and Hey!!, your labor is free. Tom ApplianceEducator.com
