tonia411
#1 Posted : Friday, February 4, 2011 5:50:39 PM(UTC)
tonia411
We had a power surge into our home tonight and now we do not have any power to our control panel on our dryer.
#2 Posted : Saturday, February 5, 2011 12:35:58 AM(UTC)
Here are your parts includes wiring diagrams
Replacement parts for MAYTAG MDE5500AYW DRYER- ELE | AppliancePartsPros.com
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
If the power is OK then odds are that the control board is toast.
bill von
#3 Posted : Tuesday, February 8, 2011 5:03:41 AM(UTC)
bill von
dryer light comes on, no control board all connects look find.. is their a reset..or any other part other then control board model #mde6800ayw
thanks
Maytag Dishwasher control panel doesn't light up (Dishwasher Repair)
by ms031317 11/20/2013 12:16:24 PM(UTC)
