jbintenn
#1 Posted : Thursday, February 3, 2011 4:43:21 AM(UTC)
jbintenn
I am having a problem identifying the defrost timer part number for my Whirlpool #ED5PHEXNB00 side-by-side and hoping somebody can help.
I am hearing a clicking and/or popping noise and it happens right after it sounds like something is trying to turn itself on. It is intermittent. It is definitely coming from the left hand side(freezer side as you face the front). I was told that this is probably the defrost timer and/or heating element.
Thanks much in advance for the help.
Best Regards,
jbintenn
RoboJoe Industries
#2 Posted : Thursday, February 3, 2011 8:28:46 PM(UTC)
RoboJoe Industries
Popping and crackling sound is normal. That's the sound of water hitting the defrost heater during a defriost cycle. As long as the unit is cooling properly, you have nothing to worry about.
http://www.upthemileage.com
http://www.appliancerepair-shiawassee.com
jbintenn
#3 Posted : Friday, February 4, 2011 4:23:38 AM(UTC)
jbintenn
Thanks for the reply.
I failed to mention that we also noticed a very strong odor (like an electronic compononent burn smell or excessively hot component smell) that filled our kitchen just before we started noticing this intermittent clicking and/or popping sound.
And that is why I believe something is not quite right with the unit even though, yes, everything for now appears to be working okay. Ice Cream has appeared to be softer than normal lately, though, but the fridge seems to be cooling normally.
So again, I can put my ear right in front of where you change out the water filter in front of the fridge at the bottom and distinctively hear the sound of what sounds like something trying to turn itself on followed by a pronounced clicking or popping sound and then it gets quiet again. Then after a few minutes, it will do it again....and again....and again...until it will finally stop for awhile only to start all over again. This intermittent cycle keeps occuring everyday.
Does this unit have a defrost timer (the electronic version) and would it be located towards the front left? If so, what is the part number?
There is nothing in the parts manual that says "Defrost Timer" and I am having trouble identifying it. Is this it?
Part #AP4981918
(Please see attached pic.)
Anyway, the defrost timer is what I have been led to believe is the culprit so that will be the first thing I will try and replace unless I hear different from the experts on this forum. :)
Thanks again very much for your help.
jbintenn
jbintenn attached the following image(s):
jbintenn
#4 Posted : Friday, February 4, 2011 4:50:15 AM(UTC)
jbintenn
Well since I posted my long winded reply, I found this info on this forum on another thread that is similar to mine so I will try it out.....
If this might help someone else, here is the link:
http://www.applianceaid.com/adaptive_defrost.html
Looks like on the newer units the Defrost Timer is now referred too as an Adaptive Defrost Control Board (see attached pic for the one I need for my Whirlpool).
But this link has some excellent (fairly simple it seems) troubleshooting methods that I need to try to help me identify what might be going on.
Hmmm.....looks like this PCB has plenty of electronic components that could have created that 'burnt/overheating smell' we experienced too. :)
Thanks to this forum, I am getting the direction I need. :)
Well...off to do some thorough troubleshooting.
I will update with the results..... It will probably be late today or tomorrow (Saturday) before I get to proceed further with this, however.
Later,
jbintenn
Part #AP4981918
jbintenn
jbintenn
#5 Posted : Friday, February 11, 2011 2:46:57 PM(UTC)
jbintenn
Well it took longer than I had planned to get to my issue. Turns out that once I really got my hands dirty to take a look, the clicking/popping sound was coming from the right rear of the unit.....where the compressor is located.
Anyway, I took off the overload/relay switch unit on the compressor and did the smell and shake test. Sure enough one of the relays inside had fried. I had found the culprit.
Unfortunately I did not order the correct 'overload kit' and have since found that my unit is called a Starting device kit. Got it ordered just now so will be replacing that unit and should be good to go.
jbintenn
