kenneth222
#1 Posted : Tuesday, September 16, 2008 6:25:17 AM(UTC)
kenneth222
This thread is associated with one i sent a couple weeks ago but is reallly a different problem thus I started a new thread. The timer does not advance in any setting (timed dry, mositure sensing etc) The clothes dry just fine. I just have to rember to shut it off!
I am assuming that the timer motor is bad so am thinking I should just replace the timer assembly. I used my 110 volt tester and there is voltage to to the two wires to the timer motor so it looks like i need a timer. Do you agree?
libertyappl
#2 Posted : Tuesday, September 16, 2008 7:01:52 AM(UTC)
libertyappl
I would agree,. replace the timer.
Nat
kenneth222
#3 Posted : Tuesday, September 16, 2008 9:09:52 AM(UTC)
kenneth222
thanks nat will do and will report to thread
libertyappl
#4 Posted : Tuesday, September 16, 2008 9:16:52 AM(UTC)
libertyappl
hope that gets it! Good luck
Nat
