furlobr
#1 Posted : 16 years ago
furlobr
dishwasher turns on and off and now will not run for more then 1 minute, anythoughts from anyone would be appreciated. I think it is the electronic control assembly.
libertyappl
#2 Posted : 16 years ago
libertyappl
Could be a loose connection as well. worth a look.
Nat
furlobr
#3 Posted : 16 years ago
furlobr
connections look good. Any thoughts on the electronic control assembly
libertyappl
#4 Posted : 16 years ago
libertyappl
That would be highly probability. Do all the LED's lilght up with you push the corrisponding button? If you have a ohm meter you should be able to use the tech sheet to do some tests.
Nat
furlobr
#5 Posted : 16 years ago
furlobr
will do, thanks for the help!
libertyappl
#6 Posted : 16 years ago
libertyappl
any time!
Nat
