3 Pages<123>
Rich4898
#11 Posted : Wednesday, February 2, 2011 1:55:31 PM(UTC)
Rich4898
Are you sure? The start key and the bake good key don't seem to work. Is there a way to test the consule? Could the PCB that the consule connects to be faulty?
Rich4898
#12 Posted : Wednesday, February 2, 2011 2:00:45 PM(UTC)
Rich4898
Gene, another question. Could a fault in the main PCB be damaging the consule?
#13 Posted : Wednesday, February 2, 2011 3:37:03 PM(UTC)
Rich,
There is a small chance for the PCB to be bad as well but it will never cause any damage to console.
Quote:
...The start key and the bake good key don't seem to work...
Did it happen with the original console?
If not then more likely the new console is defective. It owuld not hurt if you'll order a new control board together with the replacement console. You can return it any time within 45 days even if it was installed.
- The control board Part number: AP3137864
Rich4898
#14 Posted : Thursday, February 3, 2011 9:19:33 AM(UTC)
Rich4898
Thanks Gene, I'm going to put old console back in and see if I can run the diagnostics before returning new console and ordering control board. CHEERS! rh
Rich4898
#15 Posted : Thursday, February 3, 2011 11:22:22 AM(UTC)
Rich4898
Hi Gene,
Before completely removing new console I decided to try cleaning ribbon connectors on control board with degreaser and air. It worked. Console and range seem to work properly, however , I still can't get diagnostics to run. When I enter string and hit Timer Set Start 6AS does not display - only timer clock display?
#16 Posted : Thursday, February 3, 2011 12:13:11 PM(UTC)
Rich,
Just to compare the results can you put back the old console and run the same test? Before you do it clean the ribbon cable edge connector as instructed in the previous post.
Rich4898
#17 Posted : Friday, February 4, 2011 7:27:29 AM(UTC)
Rich4898
Hi Gene,
Put old console back in after cleaning connector with electronic component cleaner. Old console worked same as new console. Touch pad appears to be working but I can't get the diagnostics to display after entering your string of commands. Do you think my old console is good but the problem is the control board?
Rich4898
#18 Posted : Friday, February 4, 2011 7:30:14 AM(UTC)
Rich4898
Gene,
One other note. Even though range seemed to be working properly it actually is not as the oven will not come up to entered temperature.
#19 Posted : Friday, February 4, 2011 12:26:02 PM(UTC)
Rich,
You may want to order the control board and give it a try.
Rich4898
#20 Posted : Tuesday, February 15, 2011 10:18:15 AM(UTC)
Rich4898
Gene,
Control board was the gremlin. End of service test and all functions working okay now. Thank you for your help.
CHEERS!
Rich
Guest (4)
3 Pages<123>
