claninga
#1 Posted : Monday, January 31, 2011 10:57:03 AM(UTC)
claninga
the last week or so we've noticed that the arms of the dishwaser won't spin when it's- running.:( UserPostedImage
#2 Posted : Monday, January 31, 2011 3:35:13 PM(UTC)
A model number may help others help you.
Model Number Locator
claninga
#3 Posted : Monday, January 31, 2011 5:02:04 PM(UTC)
claninga
58715104801 model number:D
#4 Posted : Wednesday, February 2, 2011 12:18:50 AM(UTC)
Your unit is actually manufactured by Electrolux/Frigidaire
Replacement parts for KENMORE 58715104801 | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154686201.pdf
And a manual which I beleive covers your unit but am not 100 % sure.
http://frigidaireservicetips.com/pdfs/484_2.pdf
First you have to determine if the wash pump is running during wash.
Next check the holes in the wash arms and the filters.
May also be a low fill condition.
Most units fill to just under the heating element.
This can be checked by adding a couple quarts of water after each fill during a cycle. If it now washes OK then check the fill valve.
Just be careful to not overfill it.
Often if the fill is low you will also hear a growling sound because the pump will cavitate (suck in air).
The most common cause is a dirty screen filter on the input side of the fill calve. Remove the valve from the unit and clean/check the filter.
Do not permanently remove it from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
claninga
#5 Posted : Wednesday, February 2, 2011 6:46:40 AM(UTC)
claninga
http://manuals.frigidaire.com/p...df/Kinston/154686201.pdf
thank you very much! we will check it out. it seems to go through a normal wash cycle and i check the holes in the arms regularly. i'll let you know how it turns out.:)
Guest (4)
