I have a GE model dde7100mcl and have been searching for a part that I fear is discontinued. Hopefully I can find a suitable replacement here. I haven't quite found the part on the Cabinet front part of the diagram. The number that I believe it to be is 395 on the cabinet front of model DDE7100mcl. it shows two different parts for that piece AP2043109 and AP2043111 both discontinued. It is a paper type filter that is sandwiched in between the metal parts of the door. It seems to be a barrier between the door of the dryer and the lint trap. the only reason that i am replacing it is brcause the piece has mold on it. I have included a few pictures of the part. Is there anything that I can do? jason kelley attached the following image(s):
A lot of them dryers simply have a piece of cardboard in there.
so is there a reason for that cardboard and should i replace it or just throw it away?
Keeps down the racket from vibration is all I can figure out
